13 years agoMax II UFM Data Synchronisation
Hi, i want to use the UFM memory in MAX II ( parallel interface ) like the component declaration:
component data_flash is port ( addr : IN STD_LOGIC_VECTOR ( 8 DOWNTO 0); di : IN STD_LOGIC_VECTOR (15 DOWNTO 0); nerase : IN STD_LOGIC; nread : IN STD_LOGIC; nwrite : IN STD_LOGIC; data_valid : OUT STD_LOGIC; do : OUT STD_LOGIC_VECTOR (15 DOWNTO 0); nbusy : OUT STD_LOGIC ); end component; This parallel interface is asynchrounus to my system clock. It is advisable to use a register chain ( two register to avoid metastability ) for the data_valid and or nbusy signal to take the outgoing data into my register ? thank you, NicolasNo RepliesBe the first to reply
