16 years agoMax II startup glitch
Hi I have created a PCB using a Max II EPM240T100I5N for a state machine + logic. It works 100% except for the fact that the outputs are high for 100us in duration (1 clock cycle) at startup. ...
16 years agoThanks Guys
I suspected it was the pins tri-stating at startup, but I assumed there was a way to override this behavior. Probably not going to bother changing the pull-downs (no issues with the glitch yet) Many thanks for the advice Meng
