16 years agoMax II startup glitch
Hi I have created a PCB using a Max II EPM240T100I5N for a state machine + logic. It works 100% except for the fact that the outputs are high for 100us in duration (1 clock cycle) at startup. ...
16 years agoIn verilog HDL,you can use "initial"constructs to implement that.
In setting->Analysis&Synthesis settings->more settings->Ignore Verilog initial constructs->off This can implement the power up initialization
