MAX II EPM240G Support.
- 3 years ago
EPM240GF10015N is an invalid part name. I presumed you are referring to EPM240GF100I5N.
Attached quartus.ini to enable the EPM240G device in Quartus 13.1.0.162 Web Edition.
- Add the quartus.ini file in your project directory (same level as .qpf is) to update these parts or family.
- Restart Quartus and open the project to reflect the device.Best Regards,
Richard Tanp/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
The device EPM240G is most likely an engineering sample and thus it is hidden.
Could you please provide the following information so I can generate an .INI file to request Quartus to unhide the device:
Quartus version used: (e.g., Quartus Prime Standard Edition v18.1.1 build 646 )
Device Part Naming: (e.g., 10M50DAF256I5G)
Please note that the .INI will only work for that specific Quartus build, so please provide the exact Quartus version required. The latest Quartus version that I can generate the INI is till version 21.1std.1.
Richard Tan
