13 years agoMAX II Device Erase and reprogram cycles
Hello, i want to use the UFM Block in a MAX II Device to store some serial numbers. In the MAX II Device Handbook, Table 5–3. MAX II Device Programming/Erasure Specifications there is gi...
13 years agoI would take the MAX II specification to mean that you can erase and reprogram the UFM/CFM a maximum of 100 times. After that the memory may become unreliable. The minimum number of times would be zero.
