17 years ago
Max II CPLD DEV_OE and DEV_CLRn
I'm using MAX-II(EPM1270) CPLD and Here is my question:
How these CPLD DEV_OE and DEV_CLRn pins are asserted and deasserted ??
I red in MAX-II Data sheet that an option has to be set before compilation in the Quartus II software in order to controls these pins,
If I want to use these pins what I have to do and if not what to do?
Please suggest.
Thanks in advance
    The solution is to load a design that contains the serial flash loader. You can either include a SFL instance with your design or load the default SFL design for your device, that can be found in the \quartus\common\devinfo\programmer folder.
    I am facing problem during In-system Programming Using the External SPI Master Port.we can see the error below
    Error: Operation failed
    Error: Flash Loader IP not loaded on device 1
    Plz suggest any solution...
    Device used --Cyclon-III (flash EPCS128)
    Tnx & Rgds,
    viru Jawoor
    The settings can be set in Assignments/Device/Device and Pin Options. It can be found intuitively without reading the Quartus Handbook, I think. (Although the Handbook is always an option).
