17 years agoMax II CPLD DEV_OE and DEV_CLRn
I'm using MAX-II(EPM1270) CPLD and Here is my question: How these CPLD DEV_OE and DEV_CLRn pins are asserted and deasserted ?? I red in MAX-II Data sheet that an option has to be set before ...
16 years agoThe solution is to load a design that contains the serial flash loader. You can either include a SFL instance with your design or load the default SFL design for your device, that can be found in the \quartus\common\devinfo\programmer folder.
