17 years agoMax 7000: Epm7064s-5
We've been using an EPM7064S-TC44-5 with an external 100MHz clock for a while but now we have a need to increase the clock speed for our device. From the datasheet, the 7064S-5 has a fmax of 250MHz ...
17 years agoI'm not completely sure
- You can implement combinational logic at a higher frequency - A non-feedback register can possibly use a clock frequency up to fmax I don't think, that it makes much sense to push MAX7000S to the limits. You most likely won't find a 5V crystal oscillator above 125 or 133MHz and have to use an ECL or LVDS oscillator or a discrete solution with a level translator. Also the dynamic power dissipation is rather high for the 5V node. With recent CPLD, you can achieve fcnt of 200 to 300 MHz.
