17 years agoMax 2 IC occasionally gets destroyed
In my hardware environment, a "Max 2" IC occasionally gets destroyed - it pulls down the 3.3 V power supply. What can be the cause for this? Can it be anything else than electrostatic discharge? The ...
11 years ago --- Quote Start --- In my hardware environment, a "Max 2" IC occasionally gets destroyed - it pulls down the 3.3 V power supply. What can be the cause for this? Can it be anything else than electrostatic discharge? The inputs of the IC have a voltage between 0 and 3.3 V (so this should do no harm). --- Quote End --- I have the same problem on max V CPLD. All the power supply pins are short-ciruited to GND pin. I suspect te GND loop but it looks like it's not really repeatable, so far 3 CPLD have been burned during programming. Did you find solution to this problem?
