17 years agoMax 2 IC occasionally gets destroyed
In my hardware environment, a "Max 2" IC occasionally gets destroyed - it pulls down the 3.3 V power supply. What can be the cause for this? Can it be anything else than electrostatic discharge? The ...
17 years agoThank you for your advice about ground loops.
--- Quote Start --- do you have boards that still survive ? --- Quote End --- Yes, I am working currently with a board which has obviously survived. --- Quote Start --- what is unclear now is, when will your maxII be destroyed. it can be destroyed during or after programming. --- Quote End --- I don't know exactly when it is destroyed. There are only few examples of this failure. Maybe it happend always when the boards were not in use for some time. Maybe the storage place for the boards is not quite ESD proof. I will have to keep observing this issue. --- Quote Start --- you say your maxII occasionally gets destroid. is it realy dead ? --- Quote End --- The current which flows through the destroyed board is more than 500 mA (even more than 2 A in the first moment after power-up). The voltage drops to 0.43 V within a few seconds. (The power supply can't provide enough power.) The Quartus programmer tells me: "Error: Can't access JTAG chain" Therefore I would say it's dead.
