17 years agoMax 2 IC occasionally gets destroyed
In my hardware environment, a "Max 2" IC occasionally gets destroyed - it pulls down the 3.3 V power supply. What can be the cause for this? Can it be anything else than electrostatic discharge? The ...
17 years ago --- Quote Start --- and for the last point, do you have some kind of GND Loop ? PC -> Blaster -> JTAG -> PCB -> any-Interface -> PC or via some kind of measurement device like scope ? --- Quote End --- The Byte Blaster is not connected most of the time, but there may be a ground loop sometimes, e.g. because of an emulator cable. Should I disconnect the emulator cable or the scope when the Byte Blaster is connected? I would find it rather awkward. Is there a more convenient method to avoid ground loops?
