17 years agoMax 2 IC occasionally gets destroyed
In my hardware environment, a "Max 2" IC occasionally gets destroyed - it pulls down the 3.3 V power supply. What can be the cause for this? Can it be anything else than electrostatic discharge? The ...
17 years agoRecheck all max 2 pins the device on the pcb as it is realy connected with the datasheet
if you use a new unprogrammed device will it be destroyed as well ? if no check wheter you have two outputs connected. check the labeling on your device with the datesheet if you have the correct device mounted.
