8 years agoMAX 10, using LVDS differential clock input.
Is it available that MAX 10 uses LVDS clocks? I should use DSC1103 as an input clock. So I tried to use ALTPLL, but only one input clock is available not CLKp and CLKn. Are there any methods u...
8 years agoA LVDS input is represented by one interface signal, you select only the p pin of a differential pair in the pin planner or assignment editor and get the n pin selected automatically.
