LZANU
3 years agoMAX 10 programming flow via JTAG
Hi All! I have the following questions about the correct sequence to follow for MAX 10 programming devices via JTAG, especially the 10M04SAU169. 1. I noted that once converted a pof file to SVF and...
NurAiman_M_Intel
3 years agoHi,
Apologize for the delay in response as I was on emergency leave.
This is to let you know that I have consult our engineering team for this case. I shall let you know once they have provide their feedback.
Aiman
LZANU
3 years agoHi Aiman,
Thank you for your help.
I discovered that I can remove the Verify Protect feature by performing the DSM Clear command and disconnecting to the target. I noted this is the only way to read out again the content of the CFM memory (instead of 0x00). Not sure if it is the recommended way to do that.
Luca
