9 years agoMax 10 JTAG Voltage Question
Hello, I am designing a pcb around the 10M50SC (Max 10) 144 pin chip. I am confused about what voltage the JTAG lines should have. I've read that the pull up voltages for TMS and TDI ...
9 years agoA single supply MAX10 device will be either supplied by 3.0 or 3.3V. It makes no sense to use a different supply than VCC_ONE for JTAG interface. Instead use effective clamp diodes if you worry about overshoot.
