9 years agoMAX 10 in place of Cyclone IV
Well, this seems fine to me, but I thought I'd ask the experts before doing it: I've made a VHDL design that's currently working on a Cyclone IV E. It uses the internal RAM (dual port mode), ab...
9 years agoGood to know :)
Just to make sure: - The MAX 10 10M02 has configuration FLASH memory to cover a VHDL code that uses all of its resources, correct? Because I saw that it has a little bit of "User FLASH memory", but I assume it's a separate FLASH memory just for any possible user data (if any), and not for storing the configuration. Is that right? - I also saw that the 10M02 has a built-in 116MHz oscillator. Is that true? So I don't even need an external XTAL if my design don't need a very precise clock signal?
