klopez
4 years agoMAX 10 FPGA
Does anyone know where I can find more detailed information about how many PLLs each FPGA has? I an looking into the MAX 10 specifically, 10M50SAE144I7G, to replace an outdated FPGA. The document ove...
sstrell
4 years agoThis doesn't make much sense since every MAX 10 device has at least 2 PLLs.
I'm assuming you are using the IP Parameter Editor to create the PLLs and then instantiate them. You could try deleting the generated IP files and recreating the PLLs. You could also try deleting your db and incremental_db folders and recompiling to see if that fixes the issue.
If the tool still thinks your device has only one PLL, I'd try reinstalling Quartus or at least the MAX 10 .qdz. Something's fishy.
