8 years agoMAX 10 FPGA Program File
Hi, for my first project with FPGA I am using MAX 10M08 EQFP144 and USB Blaster as Programmer Tool. Now, if I program the device with the .sof file the FPGA works correctely, whereas if I use ....
8 years agoHi Alex,
thanks for your suggest. I solved with a dedicated pull-up on these pins. I tested the MAX10 between -20°C and +80°C and it works perfectly. Best regards Enrico
