8 years agoMAX 10 FPGA Program File
Hi, for my first project with FPGA I am using MAX 10M08 EQFP144 and USB Blaster as Programmer Tool. Now, if I program the device with the .sof file the FPGA works correctely, whereas if I use ....
8 years agoHi,
Have you checked with Power Analyzer tool in quartus how much power silicon is taking? Can check the power required for your board? Power requirement for the board taken care? Is plane maintained for power planes in layout. And how many ground planes are there in your board and how many vias you are using to connect the ground planes connected? Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
