9 years agoMAX 10 Flash programming
Hi, In MAX 10 FPGA, when the CFM will program ? What are the signals are related to flash ? CONFIG_SEL pin is used to select the CFM0 and CFM1 but, how the process will work ? Please explain if...
9 years agoYou program the CFM via JTAG. You can't program the internal FLASH directly from other pins. So, an FDTI device won't help you.
Cheers, Alex
