9 years agoMAX 10 Flash programming
Hi, In MAX 10 FPGA, when the CFM will program ? What are the signals are related to flash ? CONFIG_SEL pin is used to select the CFM0 and CFM1 but, how the process will work ? Please explain if...
9 years agoActually, I'm planning to use USB (via FTDI) to program the internal flash. I am confusing with how data and control signals are connected in between FTDI and FPGA to program the CFM.
