8 years agoMAX 10 10M25SAE144 problem boot from internal flash
Hi, I created a simple bitstream to blink an LED. It works fine when I download the SOF through JTAG and the LED blinks. But after I programmed the POF to the internal flash, the LED didn't blink aft...
8 years agoHi SV,
--- Quote Start --- Is there a known issue with POF internal flash programming on MAX 10 devices? --- Quote End --- No issues. We have to follow all the recommended steps & setting as per MAX 10 FPGA Configuration User Guide. --- Quote Start --- I measured nCONFIG V = 3.22V, same as CONF_DONE. --- Quote End --- This means device is Working fine.check with below option enable. --- Quote Start --- I tried to create a JIC file but it seems MAX 10 doesn't have Active Serial configuration for the internal flash. --- Quote End --- Yes, Flash is inside the device.we can use any methods below a.Generating the .pof with ICB settings. b.Programming the .pof into the internal flash. Try to load pof with below option enabled. 1.Enable the real-time ISP mode, turn-on the Enable real-time ISP to allow background programming. OR Download the device Kit.Load sample program and check. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
