8 years agoMAX 10 10M25SAE144 problem boot from internal flash
Hi, I created a simple bitstream to blink an LED. It works fine when I download the SOF through JTAG and the LED blinks. But after I programmed the POF to the internal flash, the LED didn't blink aft...
8 years agoHi Anand, thanks for your replay.
For the list of your suggestions: 1) I will probe nConfig and report back. I remember I read Intel/Altera's document somewhere about nSTATUS low after config indicating an error during the config. 2) I am going to ask our board engineer on the regulators. He told me the regulators he picked are better than those found on the evaluation boards of 10M08 and 10M50. 3) I tested the POF of the simple design on 10M08 and 10M50 evaluation boards and both eval boards work fine(with minor changes for device and pin locations since we have a 10M25 chip). I think the POF should be good. 4) I am going to use dual boot of 10M25 but for the simple config test, I only used a single image. 5) I will create a JIC file and see if it makes a difference. Is there a known issue with POF internal flash programming on MAX 10 devices? Best regards, SV.
