11 years agoMax 10 - Difference in performance between low-speed and high-speed I/O pins
Hi, Could someone please explain the difference in performance between the low-speed and high-speed Max 10 I/O pins? I have searched the datasheet and have not be able to readily find the differen...
Moki
7 years agoIt appears to be the maximum delay that you can add to input and output.
I've only found documentation[1] for it on Stratix III, but I guess it's similar on MAX 10.
According to the MAX 10 datasheet[2], minimum offset is always zero, and the maximum offset is small in the fast corner, and large in the slow corner. If you need fast I/O, it should not matter which pins you use.
[1] https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/an474.pdf
