11 years agoMax 10 - Difference in performance between low-speed and high-speed I/O pins
Hi, Could someone please explain the difference in performance between the low-speed and high-speed Max 10 I/O pins? I have searched the datasheet and have not be able to readily find the differen...
8 years agoI don't think that the old post is inaccurate. The quoted 310 versus 310 Mbps numbers are correctly quoted from the datasheet.
--- Quote Start --- one can only assume that the low-speed would be less than that. IMO 150 Mbps/MHz is a reasonable limit for low-speed if high-speed is 300. --- Quote End --- You probably miss the important point. It's so that so called "low-speed" pins don't support certain IO standards at all, e.g. no true LVDS. The speed difference for the supported IO standards is almost negligible.
