11 years agoMatrix Package in VHDL
Hello, I have found that there is matrix package provided by Altera which includes several functions that we can perform on matrices. Anyone who has already used this package?? Since I am creating ma...
11 years ago --- Quote Start --- This package uses real types. You could use the integer matrices, but the real matrices are not suitable (real types have no meaning to a synthesisor) You need to define your own types , in your own package, with the fixed point package. --- Quote End --- I have written the following code and compiled it with Quartus II. It gave me no error... I have also attached the snapshot of compilation page. I think I should use it and see whether I can achieve my result or not. What you suggest? entity matrix_multiply is port ( clock : in std_logic ); end matrix_multiply; architecture matrix_function of matrix_multiply is signal i_es_alpha : sfixed(15 downto -12); begin multiply: process (clock) variable matrix_a : sfixed_matrix (0 to 1, 0 to 1); variable matrix_b : sfixed_matrix (0 to 1, 0 to 1); variable matrix_c : sfixed_matrix (0 to 1, 0 to 1); variable resizing : sfixed (15 downto -12); begin if rising_edge(clock) then matrix_a := ((to_sfixed(1,15,-12),to_sfixed(2,15,-12)),(to_sfixed(5,15,-12),to_sfixed(8,15,-12))); matrix_b := ((to_sfixed(5,15,-12),to_sfixed(2,15,-12)),(to_sfixed(7,15,-12),to_sfixed(8,15,-12))); matrix_c := matrix_a*matrix_b; end if; i_es_alpha <= matrix_c(1,1); end process multiply; end architecture matrix_function;https://www.alteraforum.com/forum/attachment.php?attachmentid=10580
