15 years agomatlab to verilog converter request
Hi there,
Is there a compiler which can convert Matlab code directly in to VHDL/verilog format so to implement the code directly in to FPGA? I have written codes on MATLAB and would like to convert the code in to verilog format so to make my life easier.:) me w8ting for your response!!!! thnks7 Replies
u thnx a lot...
also i want to guide me in my project which is ''fpga imlementation of linear discriminant analysis for p300 signal detection''... plz guide me... - Altera_Forum
u thnx a lot...
also i want to guide me in my project which is ''fpga imlementation of linear discriminant analysis for p300 signal detection''... plz guide me - Altera_Forum
Altera's DSP Builder Advanced blockset for Simulink should be mentioned here. it doesn't convert M code, but the HDL it outputs is generally very efficient
matlab code converted to VHDL? sound interesting. :)
Almost any higher level language to verilog/vhdl conversion will not give you optimal results, except for very basic implementations. The problem is the C/Matlab/ etc. languages do not have hardware constructs, so the conversion is forced to basically generate a flat unrolled design that ends up taking more resources and running slower than the desired operation.
In one case I worked on, a software engineer tried to use a C->Verilog converter to generate code for image warping. The C code worked, but was too slow. (Taking several seconds to warp a signal 800x480 frame). She worked with an FAE for over 4 months trying to convert the algorithm to a hardware implementation. The net result was they could never get it to fit in the target device. I took the software and was able to generate a pretty small design that could do the warping at 20->30 pfs. (with 15 fps being the target update rate). - Altera_Forum
HDL coder is more a simulink tool and only a subset of embeded m can be converted.
--- Quote Start --- Hi there, Is there a compiler which can convert Matlab code directly in to VHDL/verilog format so to implement the code directly in to FPGA? I have written codes on MATLAB and would like to convert the code in to verilog format so to make my life easier.:) me w8ting for your response!!!! thnks --- Quote End --- Did you try the MATLAB site? http://www.mathworks.com/products/slhdlcoder/index.html http://www.mathworks.com/products/filterhdl/ These converters are for very specific logic implementations. There will not be a general-purpose m-file to HDL converter. If you want an optimal hardware implementation, you are better off writing HDL, and using the MATLAB model for comparison testing. Cheers, Dave
