14 years agoMapping SPI flash memory span to avalon bus.
Hi All, I have a board using an SPI serial Flash hooked on the FPGA. I would like to map the whole span of this memory on the avalon bus for making it available to the Nios (some strings in tha...
14 years agoYes, the EPCS controller will give you access to SPI based flash devices. I do not know if it will support all flavors, but I know it works with the old ST/numonix/micron M25P series
