11 years agomake: *** [my_hello_world.elf] Error 1
Hello Altera Guys; I am having problem building my software in NIOS II SBT 15.0 (eclipse) and I really need your great help. I have this message on my console and I do not know how to solv...
11 years agoThe message means that your code is too large to fit into memory. The default size for on chip memory is very small. Most of the tutorials have you use a larger on chip memory size. Look at the on chip memory module in QSYS. I should have a size large enough to fit your program. If it doesn't, pick a larger size (8K or 16K for example). Don't forget to re-generate the code in QSYS and re-compile in Quartus.
