17 years agomaintaining my result from becoming unknown state
Hello, i've got a question on how to maintain my result from becoming unknown state. let's say the original value is 11110000. however after some period of time it becomes 1111X00X making the...
17 years agohi mikedsouze,
the "after 30ns" is for pre-synthesis simulation or generating test benches as input stimulus for pre or post-synthesized VHDL. from the comp.lang.vhdl faq (http://www.eda.org/comp.lang.vhdl/faq1.html): --- Quote Start --- After clauses in signal assignment statements are not synthesised as there is no hardware primitive that has a fixed but settable delay. (Usually the delay varies significantly with temperature, supply voltage, output loading and the like). In the best case they are ignored by the synthesis tool. Hence, the statement sig <= not sig after 10 ns; will not result in an inverter with a 10 ns delay. Most likely, an inverter will be synthesized, but no attempt is made to adhere to the delay specification. --- Quote End --- to get a stable output you will want to read about clocked processes and inferring flipflops.
