17 years agomaintaining my result from becoming unknown state
Hello, i've got a question on how to maintain my result from becoming unknown state. let's say the original value is 11110000. however after some period of time it becomes 1111X00X making the...
17 years agoIf your design is synchronous you simply don't care about those unknown states, because those values of your output will be evaluated only at some clock edges.
So you should care only about the values of your result in correspondence of your active edges of the clock, and ignore what's happening in between them. If your design is asynchronous, you'd better shift to a synchronous design, so add a clock that acts to synchronize all the state changes in your machine and give reliable results at every clock edge.
