12 years agoMagjack de2-115
Hi friends, Im finishing hardware project with marvell 88E1111, same of DE2-115 and I would like to know correct name of component with datahseet. Someone can help me ?
It's a Marvell Alaska 88E1111. So, you have the right name.
http://www.marvell.com/transceivers/assets/marvell-alaska-ultra-88e1111-gbe.pdf (http://www.marvell.com/transceivers/assets/marvell-alaska-ultra-88e1111-gbe.pdf) That's also available on the DE2-115 CD. Regards, Alex - Altera_Forum
--- Quote Start --- It's a Marvell Alaska 88E1111. So, you have the right name. http://www.marvell.com/transceivers/assets/marvell-alaska-ultra-88e1111-gbe.pdf That's also available on the DE2-115 CD. Regards, Alex --- Quote End --- Hi Alex, Thanks for you attention, in cd of my DE2-115 have schematic, but dont have name of magnetic or magjack. I checked on datasheet 88E1111 and didnt find recomentadion or name of magjack that I need use with Marvell. Can you help me again? Thanks for you attention and best regards - Altera_Forum
The DE2-115 boards have been built with a number of different MagJacks. The original BOM calls up a Halo Electronics part that isn't manufactured any more. The DE2-115 board in front of me has another brand fitted - probably EOL too.
The Marvell Phy won't be fussy as to choice of MagJack. Only when you get to 10G and up you need to match magnetics/connector to the Phy. A quick search of Digi-Key throws plenty of suitable 1000Base-T MagJacks up...
