IDeyn
Contributor
5 years agoMacronix configuration device failed to work with Cyclone V
Hi all!
I have a custom board with Cyclone V (5CEBA4), and we decided to use Macronix configuration device (MX25L25645) for external configuration storage.
As it could be seen here , Macroni...
YuanLi_S_Intel
5 years agoHi Ivan,
Just want to check if SOF programming is successful and the design is able to work as intended?
Also, have you change the MSEL setting to active serial?
Bruce
IDeyn
Contributor
5 years agoHi Bruce!
Thanks for your reply.
Yes, sof programming is successful - LEDs are blinking, and MSEL setting is correct.
Ivan
