17 years agoLVDS tristating usage
Hello, 1. Could anybody suggest whether ALT_OUTBUF_TRI_DIFF can be used at the moment? I was trying to select Cyclone III, Stratix IV - and it looks like this primitive does not supported at ...
17 years agoYes,
I agree that there is no sence to tri-state inputs. But what about output pins tri-stating? I have multiply slaves and It is necessary to avoid signal contention on the slave output (looks like SPI multi-slave environment). So I need to use tri-state buffers and my bus is LVDS bus. When I connected the slave output line to the tri-state buffer and selected the LVDS standatrd for it I got the following error: Error: The differential I/O standard LVDS cannot be used on the pin Slave_O, because the specified pin uses a tri-stated output buffer. Does it mean that it is not possible to tri-state LVDS in all Altera devices? What can be a workaround for this problem?
