LVDS Signal DC offset and AC Swing
Hi, What is the value of LVDS DC offset and LVDS AC Swing of Cyclone 10 GX devices?
--- Quote Start --- LVDS outputs in GPIO banks are compatible with industry standard (Vocm 1.25V, 0.3 to 0.4V differential swing). --- Quote End --- is there any limitation in the cyclone 1o gx transceiver to create lvds signal defined as vocm 1.25 v , 0.3v to 0.4v differential swing with 2.5 gbps (1.25 ghz clock) by using the external shared clock with minimum 5 transceivers for source synchronous implementation ( 1 clock 4 data late at 2.5 gbps data rate with 1.25 ghz )? - Altera_Forum
For example, at Cyclone 10 GX datasheet ( https://www.altera.com/en_us/pdfs/literature/hb/cyclone-10/c10gx-51002.pdf ) page 19, VCM is defined as 1.25 V and Minimum Voltage swing is defined 200 mV ( 2*VID = 2 * 100 ) . There is no Max value is defined. For the data rates below 700 Mbps Swing from 0 to 1.85V, For data rates above 700 Mbps , Swing from 1,0 V to 1.6V ( For optimized LVDS receiver performance, the receiver voltage input range must be within 1.0 V to 1.6 V for data rates above 700
Mbps and 0 V to 1.85 V for data rates below 700 Mbps. ) is this correct? Am I missing something? - Altera_Forum
--- Quote Start --- "High Speed Differential I/O is the dedicated I/O standard for the transmitter in Intel Cyclone 10 GX transceivers" --- Quote End --- I found in earlier documents that LVDS is specified from 1.0V to 1.4V . 0.3V Voltage Swing and Center 1.25V with Clear figures. I assume that same values are same for Cyclone 10 GX and newer devices. I couldn't find the values described like this in Cyclone 10 GX documentation. - Altera_Forum
1. It's all in the datasheet.
2. Which pins are you asking about, GPIO or transceiver output? Transceiver don't provide LVDS standard for DC coupled links.
