14 years agoLVDS High-speed counter。
I designed a counter, used to LVDS level pulse signal count. The number of pulses per second is a few hundred or so. Pulse width is random, from 1ns to 3ns, need to count the number of pulses, the in...
14 years agoThe counter should perfectly work. But how you are reading the result?
If you read it from an unrelated clock domain, you should expect accidentally inconsistent data due to timing violations in the domain crossing data transfer. There are several ways to overcome the problem. In case of a counter, transferring gray encoded data is the most simple one. According to the low count rate of > 70 ns, you could also synchronize the pulse event to the system clock domain and count it therein. It's always easier to transfer a single a bit correctly between clock domains than a data word.
