14 years agoLVDS High-speed counter。
I designed a counter, used to LVDS level pulse signal count. The number of pulses per second is a few hundred or so. Pulse width is random, from 1ns to 3ns, need to count the number of pulses, the in...
14 years agoThe distance between each two pulses is greater than 70ns, using EP3C5E144C8, LVDS pin is PIN_101 and PIN_103. Pulse generation time is uncertain. Pulse signal is generated by a sensor.
