9 years agoLVDS connector/cable
Good morning. I am starting to design a board that mounts an Altera FPGA. This board needs to communicate with another that mounts the same FPGA. The communication takes place via 10 LVDS lines,...
9 years agoThere's a ton of choices for those speed/distance.
A couple I've used: ERNI SMC, SAMTEC QSH/QTH, SAMTEC EDGE RATE. I think ERNI SMC is rated for 3 Gbit/s, while SAMTEC QSH/QTH and EDGE RATE are rated for at least 10 Gbit/s I think. But FPC/FFC should also work fine.
