LVDS and emulated LVDS outputs
Hi everyone,
I'm sending out from FPGA a lot of signals at LVDS with low data rate.
Is it possible to use both true LVDS transmitter channels and emulated LVDS output channels together as an output LVDS channels?
- JonWay_altera
Let me put this answer in the right place: The RS and RP external resistors is to give an effective 100 ohm differential output impedance
- AGofs
Hi JwChin,
Thank you for your answer!
I'll try to use LVDS_TX IP core to check if it is possible.
But what will happen if resistor terminations (for LVDS emulated channels) will be removed?
- JonWay_altera
Hi @AGofs Theoretically possible depending on how low is your datarate. However, for the LVDS IP Core, you can give a quick try to assign part of the channels as True and the others as Emulated, and see if the fitter allows it.
- AGofs
Hi everyone,
Do you have something new about this issue?
