17 years agoLUTs vs Logic Elements/Cells
Hi, I am currently doing initial analysis on a design. I am researching different FPGA´s regarding the required resources to implement different features. I cannot find a method of relatin...
17 years ago --- Quote Start --- Hi, Also if possible is it possible to use convert Logic elements from altera to logic cells in Xilinx. Are there factors that can be used between the respective families? Basically I am looking for a general approximation of how to interchange between both LUT´s and logic elements and between logic elements and logic cells --- Quote End --- If I can prove that LE = 1.0009 LC then Altera will make me very rich and if LE = 0.9999LC then Xilinx will... This is a very hot contentious market issue. The answer is very hard and design dependant...Your research will be most valuable source of information for us all.
