16 years agoLUT help!!!
I have wrote this code for implementing a neural network.What it does is to take some values(inputs) and some weights and computes the SUM(values*weigths).What i want to do is to check if the total s...
16 years agoI use altera quartus.I compiled the code above with no error and in the compilation report it refers how many registers,alu etc will be used for the implementation.I run and the simulation and the results are ok.But what i want to know is if the way i described to implement the thing i want is correct or if there is another more efficient way.Thank you very much
