16 years agoLUT help!!!
I have wrote this code for implementing a neural network.What it does is to take some values(inputs) and some weights and computes the SUM(values*weigths).What i want to do is to check if the total s...
16 years agoWhat simulator are you using, Quartus or Modelsim?
If it's quartus, then you have to write code that would generate real logic, as that's all the simulater supports, which isnt what you've currently got.
