16 years agoLUT help!!!
I have wrote this code for implementing a neural network.What it does is to take some values(inputs) and some weights and computes the SUM(values*weigths).What i want to do is to check if the total s...
16 years agoThe output was a help signal for me to check if the results were correct.What i want to do is to read an image- lets say a 20x20 array.Then i want to apply in this image a filter.But i want to apply it in all over the image.This filter is a 4x4 array and its response is the sum of its elements.(4x4=16elements).So i thought that the best way to implement it is with the code above.
