16 years agoLUT help!!!
I have wrote this code for implementing a neural network.What it does is to take some values(inputs) and some weights and computes the SUM(values*weigths).What i want to do is to check if the total s...
16 years agoIn your loop you have 4 values. Are you planing on 2*X1 + 2*X2?
you are still thinking VHDL is a programming langauge. The way you are using it is not really correct. Please try and work out the digital hardware before writing the VHDL.
