16 years agoLUT help!!!
I have wrote this code for implementing a neural network.What it does is to take some values(inputs) and some weights and computes the SUM(values*weigths).What i want to do is to check if the total s...
16 years agoyou have 4 inputs x1/x2/x3 and x4. Also You are shifting the weights so you want to use the old weight values as there is only 1 weight input.
