16 years agoLUT help!!!
I have wrote this code for implementing a neural network.What it does is to take some values(inputs) and some weights and computes the SUM(values*weigths).What i want to do is to check if the total s...
16 years agoWhat you want is the multiply unit, with 4 of them in parallel and then sum the results from each one.
With that, it will take 3/4 clocks to get your result.
