16 years agoLUT help!!!
I have wrote this code for implementing a neural network.What it does is to take some values(inputs) and some weights and computes the SUM(values*weigths).What i want to do is to check if the total s...
16 years agoI found a vhdl code for a simple mac unit in this forum:
http://www.altera.com/support/examples/vhdl/vhd-unsigned-multiplier.html http://www.altera.com/support/examples/vhdl/vhd-signed-multiply-accumulator.html Is it write to use one of them(with the diferrence that i will have 6 inputs,3 inputs and 3 weights).Or can i modify it somehow to use just 2 inputs?What i mean is to insert the first 2 inputs do the computation,then insert the next 2 inputs do the computation etc. Thanks
