16 years agoLUT help!!!
I have wrote this code for implementing a neural network.What it does is to take some values(inputs) and some weights and computes the SUM(values*weigths).What i want to do is to check if the total s...
16 years agoI store those as variables because every time i insert an input their values will be changed.As far as i know variables are used inside process(because their values change every clock time) and signals are constant values.(if i am right).I will try to explain you what exactly i want to do so you can help me.
I want to insert some inputs(lets say 3),each of one has one weight(random).So i would like to multiply each input with its own weight and then compute the sum of them.Then i would like to compare this sum with a predetermined threshold and if the sum that i have computed is greated than this threshold its ok.But if the sum is less than the threshold i would like to correct the values of the weights so the total sum is greater than the threshold.I hope i explained it good. P.S Sorry for my bad english
