16 years agoLUT help!!!
I have wrote this code for implementing a neural network.What it does is to take some values(inputs) and some weights and computes the SUM(values*weigths).What i want to do is to check if the total s...
16 years agoLooking again at your code:
the stored value weight(m) is never used. you expect to multiply and accumulate unregistered values. At most, I recon the max clock speed will be very slow, maybe a 2Mhz if you are lucky!
