12 years agoLPM_ROM, I am a newbie please help.
LIBRARY ieee; USE ieee.std_logic_1164.all; LIBRARY lpm; USE lpm.lpm_components.all; LIBRARY altera_mf; USE altera_mf.all; ENTITY LPM_ROM_MEGAFUNCTION IS PORT( A_address :IN std...
12 years ago--Look at this....
--You need the PORT MAP after the begin. I am not sure this will work for you --but it is definitely closer. LIBRARY ieee; USE ieee.std_logic_1164.all; LIBRARY lpm; USE lpm.lpm_components.all; LIBRARY altera_mf; USE altera_mf.all; ENTITY LPM_ROM_MEGAFUNCTION IS PORT( A_address :IN std_logic_vector (7 downto 0); Sclk :IN std_logic; Data :OUT STD_LOGIC_VECTOR (0 DOWNTO 0)); END LPM_ROM_MEGAFUNCTION; Architecture Behavioural of LPM_ROM_MEGAFUNCTION is component Variation1 PORT ( address : IN STD_LOGIC_VECTOR (7 DOWNTO 0); clken : IN STD_LOGIC := '1'; clock : IN STD_LOGIC := '1'; q : OUT STD_LOGIC_VECTOR (0 DOWNTO 0) ); end component; --SIGNAL Signal_1, Signal_2, Signal_3 :std_logic; BEGIN --address => A_address, --clock => Sclk, --q => Data THE_COMPONENT_YOU_WANT: Variation1 PORT MAP ( address => A_address, clock => Sclk, q => Data ); End Behavioural;
